I have pre-select highlight on, but when I query, intent edge isn't an option. If I use "pick from list" intent edge isn't an option. If I change the filter to "intent chain" from "all" while in the round creation, it doesn't find anything for me to select.
I created a part that is just an extruded rectangle to test this on.
I created this config.pro for Wildfire 3.0, but was using it on a different computer/different build before.
Carrie
