Internal Browser always blank
sgaynor
3-Newcomer
Hey,
I'm running 3.0 M080. I've recently had my internal browser drop out completely, and I can't trace it to any specific action that caused it. When I open Creo, the "3DModelSpace" and "Browser" tab pop up automatically, but nothing loads. It sits blank and idle with no loading indicator regardless of if I type in a web address or select Windchill Cabinets/Workspace from the Common Folders navigation pane. My server status is online, and I can swap workspaces successfully. In order to pull down WC items to a workspace, I have to add to the workspace from my browser, close out CREO, and it will propagate to the workspace upon restarting.
I've already checked the normal culprits in my config file. These are my current browser settings:
browser_limit_to_ie9_mode - yes
windows_browser_type - ie_browser
I've exhausted my help resources. Anyone have any ideas?
1 REPLY 1
arenteria-2
(To:sgaynor)
Did you find a solution that worked?
