Internet Explorer 11 issues with Creo embedded browser
jfrankovich
11-Garnet
Has anyone experienced scripting errors in the embedded browser of Creo 2.0 after updating to Internet Explorer 11? I just saw my first case today. Debugging settings and registry edits don't appear to resolve the issue. Removal of IE11 is the only option.
John Frankovich
The GSI Group LLC
www.gsiag.com<">http://www.gsiag.com>
14 REPLIES 14
msteffke
(To:jfrankovich)
Did your system auto-update, or did you update it yourself. I'm asking
because our IT group told me there are many upgrades coming this week.
I'd prefer to head this off.
Mark Steffke
Engineering System Administrator
The Delfield Company
Manitowoc Foodservice
T 989.775.9215 or 989.773.7981, ext 12484
Integrity, Commitment to Stakeholders, and Passion for Excellence
As PTC has not tested or support IE 11, let alone IE 10, you will need to uninstall it.
To prevent yourself from getting the update, search for the IE 11 blocker tool from Microsoft. Follow the instructions to download and install it. It adds a registry entry to not automatically install the update, although a user could still install it manually. There is a blocker for IE 10 also, and Microsoft issues the blockers for each new version of IE.
Mark Plimley
PLM Architect
Certified in Windchill MCAD Data Management
MarkP@NxRev.com<">mailto:MarkP@NxRev.com>
NxRev Inc.
Product Development Solutions
3375 Scott Blvd. Suite 306
Santa Clara, CA 95054
FWIW, we are on Creo Elements Pro 5.0 M130 & WC 10.0 M020 and had a user self-updated to IE11 today. He got the script errors as well. Rolling back to IE10 fixed it. I have heard no other complaints here so I dont think it was an autoupdate issue. Yet...
FYI IE 11 was part of an autoupdate package that the user got this week. I have not seen this particular update installed from any other users with autoupdates, so far.
As far as IE10, we have not had any issues with it since addressing an initial Javascript coding issue.
John
Or you could just ignore IE and use Mozilla for your embedded browser instead . Works a treat.
Paul
PTC Support suggested to me to use:
windows_browser_type mozilla_based_browser
in my config.pro for Creo 2.0 M030. This is working well at our site so far for about 5 users.
Have you have a user crash yet with a model open? There is a bug that wont let you get past the retrieve screen upon reopening Creo. FYI
Case Details - 10935042
Case Information
Case Assignee
Vidya Vadakoot
Status
SPR Filed
Severity
Severity 1 - Business Critically Impacted
Escalation Status
M0
Date Created
06-Aug-2012
Date Last Updated
24-Oct-2013
Date Solution Provided
ITAR
No
Product Information
Product
Windchill PDMLink
Release
10.0
Datecode
M030
Technical Area
Interaction with Creo Parametric & Pro/ENGINEER
Issue Information
Short Description
If Creo crashes and I get the Retrieval Screen i CAN NOT get back into Creo. The window is not clickable.
Symptoms
Steps to Reproduce
Error Messages / Warnings
Reason for Closure
Status Details
11/1
Issue was reproduced in house and SPR 2155552 is filed
10/26
Issue is specific to certain config.prop options which connect to Windchill
TSE trying to reproduce the issue
Related Documents
Type
Number
Description
SPR
2155552<">https://www.ptc.com/appserver/cs/view/spr.jsp?n=2155552>
Cannot click on Retrieve or Continue or Close(x) button in the 'Retrieval' window on starting Creo Parametric after a crash when Windows_browser_type is selected to Mozilla_based_browser
Case History
Comment created by Vidya Vadakoot (PTC) on 24-Oct-2013 14:20:40 EDT
R/D updates that the issue is not reproducible in pre- production builds of Creo 3.0 in internal testing.
We have been encounting these same script errors on some test PC's that were upgraded to Internet Explorer 11 (from IE7 or IE8).
We are using Creo Elements Pro (aka: Wildfire 5) M150 with Windchill Intralink 9.1 M060.
PTC's knowledgebase says that we need to go back to IE8, or upgrade Windchill to 10.x.
Can we force the embedded Mozilla browser to use our proxy, and lock out the end-user from disabling/changing the proxy settings?. (Windows 7 Pro)
Gerry Champoux
Williams International
Walled Lake, MI
In Reply to John Frankovich:
John Frankovich
The GSI Group LLC
Hi Gerry,
IE11 is not scheduled to be supported until the approximate timeframe of August 2014. I've had several talks with PTC regarding this.
We are on WC10.1 M040 and the IE11 issue is scheduled to be supported only with Windchill 10.2. I know WC10.1 M050 introduced support for Windows 8.1, which has IE11 by default, but that is scheduled to roll out at PTC's 2014Q3 2014.
We, unfortunately, do not have the luxury of uninstalling IE11, so embedded mozilla browser is our only option for the time being,which seems to require regular internalbrowser cache clearing.
Has anyone any success using compatibiliy mode or developer tools (F12)?
In Reply to Gerry Champoux:
Gerry Champoux
Walled Lake, MI
John Frankovich
The GSI Group LLC
There is a new option in M100 I believe that can force ie 9 compatibility even if using IE11.
Browser_limit_to_ie9_mode yes
Limits Internet explorer to IE9 standards mode even if higher version is installed.
My understanding is that
PTC's browser_limit_to_ie9_mode yes and MS's compatibility mode (can be set by URL in IE11) seem to be synonymous with 32 bit.
If so, this would require 32 bit Java and associated 32 bit Java browser plugins installed, even on 64 bit machines.
Many IT organizations when configuring 64 bit machines only install 64 bit Java.
-Marvin
On 05/20/14 12:19, Gerry Champoux wrote:
> My understanding is that browser_limit_to_ie9_mode applies only to Creo Parametric 2 only.
> In Creo Elements Pro (M180) this config option is invalid.
> Does anyone know if it is valid in a later build?
Still invalid in Creo Elements/Pro 5.0 M220.
> In Reply to Andrew Hermanson:
> From: Gerry Champoux [
