Intralink 3.4 M062 with Windows 7
ssureshkar
HI,
Hi, I am trying to install Pro/INTRALINK Client r3.4 M062 on a 64-bit PC with Windows7
The installation goes just fine, but when I try to launch Pro/I I get the PTC window to pop up, but the log-in "window" never comes up. Can anyone give me some guidelines or instruction or tips on getting INTRALINK r3.4 M062 Client to work on a Windows 7 64-bit pc.
I have also seen some suggestions like changing the compatibility mode and the modification in the intralink batch file, but it does not work. Is it like we need another OS like XP or vista to use intralink, does windows 7 alone wont work.
Thanks in advance.
See this thread for the solution:
http://communities.ptc.com/thread/33016
