Is there a Drawing config option method?
Newbie
~hey all, again...
next question in my automation quest is... Is there a Pro/TK function for setting a drawing file config option? The in-session equivalent would be (if memory serves me right as i'm not at ProE computer): File > Properties > Drawing Options > make selection > add/change to new value. I would like to change a setting and re-save the drawing. I initially thought ProSetConfigopt() [or is that ProConfigoptSet()] was the function, but after testing it appears this only changes the config.pro options and not the .dtl drawing options.
any help is appreciated. i will post summaries
thanks
-mark
2 REPLIES 2
Highlighted
RE: Is there a Drawing config option method?
Hi Mark,
A work around method can be, try editing your default/configured *.dtl file itself programmatically.
V.Amar
Team Leader - Programming
Idola Fori Design Works Limited
Hyderabad
India
hi all,
Mark, you could use ProInputFileRead and PRO_DWG_SETUP_FILE as the third argument.
HIH.
FV.
