Is there a way to set Creo to keep only 3 files per part?
rmuller
I know I can set Creo to not to keep file versions but would like to keep 3 and no more. Thanks.
Also I know I can use purge.exe to clean folders but I dont want to do that. There must be a way to do what I want, isnt there?
requested functionality is not implemented in Creo. You can use external utility, for example http://www.inneo.co.uk/product/genius-tools-purge/?_ga=1.31967550.1820602932.1455110544
MH
Martin Hanák
MH
Martin Hanák
Thanks Martin. I will give it a try.
