Isometric Dimensions
CBenner
Has anyone worked much with 3D dimensions in an isometric view? I did this 2 days ago on a drawing, with no problem. Today I have to do a similar type of drawing for a different project, all the settings are the same as the previous drawing, and all of my dimensions show up in a linear orientation. Well, not all of them... about half.
Chris Benner
Autodesk ® Expert Elite
Have you got 'allow_3d_dimensions' set to 'YES'?
CBenner
(To:JosephLord)
Yes. First thing I checked. I am using the same settings as the previous drawing that this worked on. And on this drawing, SOME of the dimensions come out iso,... some come out ortho. I've noticed, however, that if you show a dimension with that setting turned off... erase it, and turn the setting on, it will NOT revert to iso. Once you've shown it, you seem to be pooched on that part. My solution seems to be.... delete this assembly and start over with new parts that have never had the dimensions shown. PTC... Work on your 2D drawing side!
Chris Benner
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
