I use the CLASSPATH E:\Program Files\proeWildfire 2.0\text\java\pfc.jar
PATH C:\j2sdk1.4.2_18\bin
I rename the AsyncInstallTest.java as AsyncInstallTest.java_async
I could able to run from the DOS window E:\Program Files\proeWildfire 2.0\jlink\jlink_appls\install_test>javac *.java
I created the class files MenuButtonListener.class,pfcInstallTest.class,RegenAL.class and StartInstallTest.class.
I set the config options Jlink_java2 as On and jlink_java_command 'C:\j2sdk1.4.2_18\jre\bin\java.exe'
When i try to register the application using the Tools>Auxially Application It shows not Install Test in not running and the Pro/E message areas show it is successfully running the application.I attach the screen shot for more info.
Let me guide me how do i resolve this.
With regards,
Kishore V
Hello Amar,
I welcome for your suggestion.Once your .java files compiles you get .class file.But you wrote
"All java class files must end with .java extension" it is bit confuse me.Any how could able to resolve the issue by setting the Set working directory to the .class filesand i register the application,it able to register.
You are still in Idilo Floria.....
With regards,
Kishore V
