TAN 144494says following:
Certain J-Link programs compiled well after Pro/ENGINEER release 18.0 cause the following message to be reported in the std.out when loaded automatically into Pro/ENGINEER Wildfire 4.0:
A pre 18.0 Pro/DEVELOP application "<program name=">" was found.
For faster startup please add "REVISION 0.0" to <protk.dat>"
The version check causing this message to be displayed currently has an error and has been addressed Pro/ENGINEER Wildfire 5.0. See Alternate Technique.
The error has no impact on performance and can be safely ignored. For users wishing to prevent the error message being reported to std.out add the line "REVISION 0.0" to each auxiliary application entry in the protk.dat.
