Just installed Creo 3
John.Pryal
Hello all, i just installed Creo 3 out of curiousity. I have no immediate plans to start working with it, justed wanted a look. I currently work with Creo 2 & Creo Elements/Pro 5. I configured my Creo 3 install, start up directory, config files etc. all looks ok so far. I was a little nervous my other 2 versions would screw up, but thankfully they fire up fine, apart from one thing with the older Creo Elements/Pro. I get the following message alert (see image). I have just been clicking 'Install later' & things seem to work fine from there on in, but i don't want to see this message every time i launch the software. What would happen if i clicked 'install now'? It is vitally important that i can continue to work with this version, because many my customers still use this. Any advise would be greatly appreciated.
John
This is due to product view and to correct this, browse to <Install location Wildfire 5.0>\install\addon and execute ProductView_Express_32_64.msi and repair the installation.
8 REPLIES 8
That would scare me too
Happy to see more adventurous people doing this with success.
Did you have to get a new license file from PTC or did Creo 3 work with the current license?
Hi Antonius, a new license file was required. I did some further testing this afternoon, everything seems fine apart from the message alert mentioned above. I will try Mahesh's suggestion tomorrow to see if it cures it. First impressions, the UI is very similar to Creo 2, almost identical in fact. They appear to have changed/rehashed all the icons, I don't think transitioning from 2 to 3 will be a problem. I copied my config files & UI customisation file from Creo 2 to 3, & they seem to transfer ok, my mapkeys appear to work, but I may not have tried them all.
I was eager to try the new "unite technology", I opened a native inventor model & got 1/4 of a model, the same model opened ok in Power Shape, so not such a great start there.
John
I believe alot of the "unite technology" isn't there until build M030.
Thanks John. I will wait for M010 but this is good news.
I am mostly interested in the new realtime rendering upgrades.
Also some of the new surface and round capabilities.
Like you, I have projects that must continue in Creo 2.
Thanks Mahesh, that was obviously the root of the problem, i did as you instructed, & it launches cleanly now.
Thanks again
John
Just noticed something kind of weird. I have a gap between icons in the quick acces toolbar. When i hover over the gap, 'rename' appears. I have this command added to the toolbar, i use it frequently. The icon is there, only now, it does not have a picture associated with it. In Creo 2, the rename icon has a picture. If you access this command through File, Manage File, then the rename command icon has a picture. I know in the scheme of things this is a minor issue, it just strikes me as strange.
John
Certainly worth reporting, John. Its the only way to nip these little niggles in the bu..d.
