Creo crashes when loading. Is this graphics card compatible?
Maybe something else?
Creo Parametrics.
Nvidia GeForce cards are not certified. However, that does not mean they do not work. There are limitations using GeForce cards with Creo Parametric.
Try removing all configuration files from your setup and launch Creo as a plain vanilla system.
Another option is to set Creo to use a generic graphics setup.
Put this as the only entry in a new config.pro file.
graphics win32_gdi
Where do I create the file?
