Licence Issue
ptc-1873470
7-Bedrock
Licence Issue
I've just encountered a problem when installing Creo 2 on a machine in te building. I've installed it onto many others using the same method, we also have a licence server setup which takes care of the licencing of Creo 2. However after installing the software this time i'm getting a licencing error saying it's not valid for that version. Does anyone know if the Installer looks on the internet for updated files for the software and could this be what is causing the licence issue?
Chris
I've managed to fix the issue now. Thanks for your replies, it seems that our pro engineer licence server was interfearing with licencing.
Chris,
What is there in error message?
Please add a image of error.
Christopher,
Creo 2.0 installer uses license file located on license server, only. Creo 2.0 license file has to containt INCREMENT block containing 33.0 value.
Example:
INCREMENT PROE_FoundationAdv ptc_d 33.0 permanent ....
Martin Hanak
Martin Hanák
