When I try to install the licence for creo student using setup I have an error message.
What can I do ?
Thank you
the above message tells you that license file is available.
What is inside this file? If it contains valid license then you can continue with Creo 7.0 installation. The file cannot be used for installation of Creo 8.0 or higher.
