Dear Sir/ Madam.
this is error license PTC Creo Elements/Direct Drafting work not good, plz help me with informations below.
Last time we install Creo Elements/Direct Drafting version: 18 and managed license version 20.0 in win 7 - 32 bit this license and software working good. about 30 day Customer update win 10 -64 bit and install Creo Elements/Direct Drafting version: 18 and managed license version 20.0, some times license manager working some time it not working (we have many error).
Plz help me support this problem.
You can use the "Case Logger" tool, here: https://support.ptc.com/apps/case_logger_viewer/auth/ssl/log
Are articles such as CS210263 and CS225206 helpful?
Thank you for your help!
But i am useing Creo element/direct drafting verson 18.0 not 18.1 .
So win 10 64bit can support the verson 18.0 ?
See CS65690.
According to Creo™ Elements/Direct™ Drafting 18.1 System Requirements, the 18.1 is supported by win8(x32).
But according to Creo™ Elements/Direct™ License Server 20.0 System Requirements, tje 20.0 is only supported by win10(x64).
Are you using win10(x32)?
i am using win10(x64).
Unfortunately, CED 18.0 does not support Windows 10
Therefore, you may encounter a License Error when using CED 18.0 with Windows 10.
thank you so much! I got it
