This is the error I get when I try to load Creo Parametric 3.0 on a 64-bit Windows computer. This is the school version.
You can ceate a support request from the linked page. Someone will contact you with regard to help solving the problem.
Hello!
I have also met the problem "License Request Failed for Feature". But after I click the link you supplied, I can't find the corresponding solution. Can you help me?
