I have a very simple question.
How do I see the status of licenses on my network at work? I tried ptcstatus.bat and don't really see what I am looking for. I would like to see all the creo parametric licenses in particular and if used or borrowed.
WayneF
My bad. I just looked again at ptcstatus and I do see the licences. They are called "Proe_DesignEss". Not sure what that means, but makes sense. We have 46 licenses available and 4 used. Sorry.
Try this on your FlexNet Server:
http://localhost:8090/dashboard?licenseTab=floating&vendor=ptc_d&admin=systeminfo&selected=#
Hi Ben,
The address does not go anywhere.
Wayne
I was afraid of that 😞
This a view of what I get with that command:
When I press on Concurrent, it lists all of the modules and then I can see who has a license in use.
What information is missing from the ptcstatus.bat report?
My bad. I just looked again at ptcstatus and I do see the licenses. They are called "Proe_DesignEss". Not sure what that means, but makes sense. We have 46 licenses available and 4 used.
Thanks Ben!
DesignEss stands for Design Essentials.
Here you can read the feature inside every license.
https://www.ptc.com/en/support/article/CS165221
Thanks Marco,
I have closed this post. But I will look at what you sent me for a more detailed look.
That list is a bit out-of-date.
The new license names are:
Design Essentials
Design Advanced
Design Advanced Professional
Not sure if there are others, those are the 3 we have.
