I have been using Creo 9.0 for the several years at company,
Suddenly, I cannot run Creo because of license error message and AFX&IFX fail.
Any idea how to fix this problem?
I tried changing the settings to fix this problem but it didn't work.
1. License Warning
Requesting PROE Engineerlll ...
Requesting ROE_MechFoundation ...
-15: Cannot connect to license server.
Run ptcstatus.bat for server status
2. AFX failed to load.
3. IFX failed to load.
About this error - "Error "(-15) Cannot connect to license server system" while launching FLEXnet enabled applications": https://www.ptc.com/en/support/article/CS44661
1. License Warning
problems 2 & 3 are "children of problem 1".
If I were you I would open <CREO9_install_dir>\Creo 9.0.x.0\Parametric\bin\parametric.psf file in Notepad.
In my case it is E:\PTC\Creo9_020\Creo 9.0.2.0\Parametric\bin\parametric.psf.
Line starting with ENV=PTC_D_LICENSE_FILE-= contains license server information.
You have to verify whether license manager is running on license server.
Line starting with ENV=CREOPMA_FEATURE_NAME= contains license name information.
