I am using Creo Parametric - Release 3.0 (connected) 3.0 M140
We recently changed workstation and needing new license for that MAC address, thanks.
If you are under maintenance, you can move a license from the web tools for licensing.
If no maintenance, contact your VAR or PTC directly.
Thanks for your advice, I was able to solve the problem, from that workstation, thanks again.
