I tried installing but no success. It's throwing ptc_d an error: exited with status 34 (invalid host).
I'm using binaries meant for Linux and host id of ethernet is mapped to name eth0.
Autodesk FlexLM is also installed in the same machine and is running fine.
Can anybody share procedure to install license manager in linux OS?
Dhinesh
Hello Dhinesh,
maybe that FlexLM from Autodesk runs on the machine, is the problem!
See TPI 137851 : https://support.ptc.com/appserver/cs/view/solution.jsp?n=137851
Gunter
