Lights file in start part
Good morning.
When I look at the lights (View, Model Setup, Lights) in my models, they have the following lights defined:
Default Ambient
Default Distant
Lightbulb-2
Lightbulb-3
Lightbulb-4
Spotlight-2
Of these, they are all switched on, except the Default Ambient.
Clearly, at some stage I, or someone else, has created this set of lights.
What I don't understand is this: Where is this set of lights stored? What is its filename?
I would like to modify the file so that the Default Distant light is switched off as standard.
How do I do that? I know how to switch it off, but the off setting does not persist. Next time I open the same part, the Default Distant light is back on.
I have looked in config.pro, but I can't see anything relevant.
Any suggestions?
WF4, M220
John
