An PTC Community
Beim Öffnen des Programmes PTC Creo Parametric erscheint ständig eine Warnungsmitteilungs-Liste mit einer Fehlermeldung (Bild unten).
Könnten Sie mir vielleicht, bezüglich diesen Fehlers, helfen ?
Mit freundlichen Grüßen
Martin,
is your computer name ACER_ASPIRE ? Or can your PC communicate via LAN with ACER_ASPIRE ?
MH
Thanks for your answer,
Yes the name of my laptop is ACER_ASPIRE.
MR
run services.msc applet to see list of Windows services.
Look for one of following services and check if it is running:
FLEXlm server for PTC
lmadmin_ptc
Upload log files for me to check.
MH
where should i locate the files?
it looks like log files are located in C:\Programme\FLEXnet Admin License Server\logs directory. You can upload them using procedure described in How to attach file when you Reply to a discussion.
To see Services dialog box, simply search services.msc file and launch it.
Q1: What Windows version do use use ?
Q2: What Creo version do you use ?
MH
Hi Martin,
C:\Program Files\FLEXnet Admin License Server\ptc_inst
...Hope this is the right link.
I use the version "windows 8"
I use the creo version "Creo Parametric 1.0"
MR
does C:\Programme\FLEXnet Admin License Server\logs directory exist on your PC ?
Open Services dialog box and look for lmadmin_ptc and FLEXlm server for PTC.
To open this dialog box, simply search services.msc file and launch it -OR- open Control Panel and click Administrative Tools > Services. Ask some friend who knows, how to do this, if you do not understand what I am talking about.
MH
