Main Menu Icons
ptc-919987
1-Newbie
Main Menu Icons
Hi there, normaly i always have side icons in the main menu. e.g. in the menu File> Save there is a small disc at the side. I do not see those icons any more in any of the main menu's. Is there for example a configuration that i can use or could it be du to a start up batch file that i am using now to set my environment? Regards, Ferry
2 REPLIES 2
Your config.win sets your menus up along with which icons to show. Check to see that your config.win is in the start directory of Pro-E. Also you will need to have a model open in order to see all of the icons, otherwise you will just have file new and couple other menus available.
Hi, Yes thank you. I found the Menu icons settings in customize toolbar>options and Menu display. show icons! Thanks.. Ferry
