Main Menu Icons
ptc-919987
Main Menu Icons
Hi there, normaly i always have side icons in the main menu. e.g. in the menu File> Save there is a small disc at the side. I do not see those icons any more in any of the main menu's. Is there for example a configuration that i can use or could it be du to a start up batch file that i am using now to set my environment? Regards, Ferry
Your config.win sets your menus up along with which icons to show. Check to see that your config.win is in the start directory of Pro-E. Also you will need to have a model open in order to see all of the icons, otherwise you will just have file new and couple other menus available.
Hi, Yes thank you. I found the Menu icons settings in customize toolbar>options and Menu display. show icons! Thanks.. Ferry
