Mapkeys WF2 to WF4
ParijatKoditkar
1-Newbie
Mapkeys WF2 to WF4
Hi all, We are about to migrate Ilink to PDMLink & WF2 to Wf4. I would like get clear on following... 1. Can config.pro of WF2 use for WF4? 2. if yes, does it will give any problem for mapkeys? 3. & if would want to use same mapkeys,how it can be done?
1 REPLY 1
Hello Parijat, 1 - Yes, the config.pro can be the same; but there are deleted and added options between this two version; check your config.pro on this utility to know if it's correct: http://www.proesite.com/index.html 2 - Of course: few menues change, but if it's the case, 3 - you must re-create the mapkey good luck
