Mass Prop Calcs
Newbie
Mass Prop Calcs
Guru's
RightI could just be missing a trick here, but it sdefinatly got me
beat.
I have an assembly which I used to run mass prop calcs on which worked
lovely!!! However no I bring the assembly into Wildfire (M210) and run the
same mass prop I get differenct results. I have looked throught the results
and found that if you have a sub assembly in your assembly it doesn't roll
up the mass props, just gives unknown.
Is this a fault or is my config missing something?
Thanks in advance!!!!
Colin Down
Senior designer
Oxford Instruments Superconductivity
Station Way
Eynsham
Oxon
OX29 4TL
