Hello All,
I am sure someone can point me in the right direction. I have this in my config file setup.
pro_material_dir wtpub://windchill.xxxxxxx.com/Libraries/CAD Standards/RSI-Start-Parts/RSI_Material
I populated a couple of test materials to that folder for testing. They are in the folder.
But Creo is still pointing to the default location.
Sorry forgot to add snip for the default material directory.
I think it may have to do with your Windchill registered name in Creo.
When you register the Windchill server to Creo, you assign Windchill a name, like PDM. It is this name that you use in your config.pro file for any Windchill libraries:
wtpub:\\PDM/Libraries/CAD Standards/RSI-Start-Parts/RSI_Material
The key is that ALL of your users MUST use the PDM registered Windchill name.
BenLoosi,
Thanks for the input. But no dice. Still pointing to the standard directory.
The same issue on both creo 5.0.3.0 & 5.0.2.0
Any other Ideas?
Cheers
Craig
That was it!
Case Sensitive.
Thank you so much!!!
