Is there a way to change the default of mates to Align or Mate not Offset..95% of mates are either Align or Mate not Offset. How can the get changed in my settings
Use the config.pro option: auto_constr_always_use_offset never
Thanks for the help, another question on a similar topic is how do you insert multiple item such as screws without going thru the assemble tool.
Edit, Repeat
