Does anyone know how to configure the Creo Performance Advisory to show all types of Creo Crashes (ehem..I mean, "premature Exits") regardless of cause (logging error, memory, etc) by build?
I would like to use this as a tool to see which build code/ship code is most stable for us but what I did find didn't seem to be comprehensive nor reliable data.
Thanks! Lawrence
Hi Lawrence,
If instead of "premature exit" you type "Premature", I think that will properly update the filter. Note that it seems case sensitive (which is something I'm looking into, as that's not an intuitive experience).
Please let me know if that helps.
Luke
Thank you for your reply as I think it worked, however I am still unclear on how to interpret the results.
As an example, under the exact same time frames, when I searched without any filters I get
but when I search with the "Premature" filter I get:
Interpretation:
Can you help me interpret this? I am really trying to understand stability by release while normalizing for number of users.
Thanks, Lawrence
