Good Day All,
With in Mechanica is it possible to run in batch mode using different simplified reps with various loads and contraints?
I want to use one assembly
I want to run one load and constraint case on the master rep showing all components
I want to run another load and constraint case on a simplified rep of the assembly show just one component
I would like to runMechanica inbatch mode over night and mesh the model(s) for each analysis and run
the analysis for each configuration.
Is this possible?
Will Mechanica batch mode retrieve a simplified rep of an assembly?
Don A
Thanks to Jim Holst, Kurt Stark, and Paul Korenkiewicz for their quick replys.
Sorry fo rthe delay in posting the summary.
They were correct.
For each batch mechanica setup you create, the assembly state is saved in a folder
for the batch run you have specified. The simplified rep state is also maintained.
Thanks for the insight,
Don A
