Community Tip - Visit the PTCooler (the community lounge) to get to know your fellow community members and check out some of Dale's Friday Humor posts!
X
I exported out a 2d sketch, from a pro eng part. Now I want to extrude it into a 3d shape. The program is telling me that it is in memory. I do not seem to be able to work with it. However I can see it and select it. But I do not know how to put it in true sketch mode or even extrude the existing 2d sketch...Any ideas. Thanks This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Wes, I'm not sure I understand what you have done from your question. When you say you "exported" a 2D sketch, do you mean that you Saved it while in Sketcher? If so, it's now a xxxx.sec file which you can retrieve later in Sketcher by selecting Sketch\Data from File... David
