Missing trail files...
mdebower
18-Opal
Okay, here is a new one on me..
We can't find the Creo trail files for one of my co-workers.  She doesn't have the trail_dir option set, so they should be in the startup directory, only they are not there.   Any ideas?
Ah HA!   The company config.pro has the trail_dir pointed to C:\TEMP
I swear, well I swear more than I should, but I thought I checked that...   hmmm.
4 REPLIES 4
TomU
(To:mdebower)
Are you running any type of cleanup script or routine that may be deleting them?  Maybe check other places like My Documents and the "Home Drive".
STEVEG
(To:mdebower)
Check the startup icon of Creo.  Check the Start In directory if the trail files are there.
You can also check in <install dir>\Creo 2.0\Parametric\bin.  Not sure the path for Creo 3.
...assuming you're running windows....
It may reside here.
open a Windows Explorer
in the address box type:
%appdata%\PTC
you can then enter a search for "trail"
If there is anything, it should show up.
