Model Check: model dimension
FrancescoPompeo
Anyone knows Model Check and how to config it.
I would like to create a parameter in my part with model dimension.
Thank You.
Anyone can help me?
Please explain to me a little more what you are trying to accomplish with the parameter in ModelCheck.
I need a parameter with the dimension of a box that contains my model (part, sheetmetal part and assembly). I think that it is possible using modelcheck but I don't know how to do that.
Thank You.
Hello.
If you need reports the length, width, and height of a box that would fit entirely around the model set the check parameter OVERALL_SIZE in mc\config\check\ *.mch (your checks file) - (Y Y N N Y)
Vladimir
Best Regards,
Vladimir Palffy
