ModelCHECK ASM Scope Results Table - SUMMARY
pwilliams-3
11-Garnet
Feliks,
I initially thought of that as the solution as well but I had a problem.
If I persist the results data in the appData then how would I know the
appropriate time to release the memory? I have found that ModelCHECK is
not very intuitive. Each time my check function was called the results
were given and stored in an HTML report for each object. The results at
the top-level do not contain the results for all sub components. I had to
either navigate to each component or go to the my check and see all of the
models that failed. I then had to navigate to each component that failed
my check. I was not expecting this behavior so I think this is a learning
experience for me.
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
0 REPLIES 0
