Hi All,
Has anyone had any success with the Modecheck DRW_TABLE_CELLS?
I have an issue where I need to use tables in my default format so that parameters in there will update correctly in the drawing, But this leaves them open to "tinkering" by the end user.
I'm trying to use this check to identify the metadata table then verify some of the key cell values in there have not been overwritten (i.e. &PTC_WM_LIFECYCLE_STATE hasn't been replaced with "RELEASED", OR THE :d AND :mdl getting mixed up has been an issue)
So far I've been able to get errors on every table that does not conform to the conditions, rather than the 1st value being an identifier,
Thanks in advance for any thoughts or past experience shared 🙂
Dave.
Hi @dmccandless,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
