I read modelupdate mode somewhere on internet while i was goingbthrough model check..
Could canyone let me know more about model update?
Thanks and regards
Ketan
Ketan,
From help:
"The ModelUPDATE mode allows you to automatically update models for errors generated during ModelCHECK. All the updates possible from the ModelCHECK report that do not require manual interaction such as typing or selection are automatically performed in ModelUPDATE mode. A report of successful and failed updates is generated. You can configure ModelUPDATE mode using the ModelCHECK configuration files. Note: You can run ModelUPDATE only in the ModelCHECK Interactive mode."
Example:
ModelCHECK is configured to add some parameters and when executing ModelCHECK, user needs to manually select the parameters to add, if ModelUpdate is not enabled. If it is enabled, parameters will add automatically.
Ketan,
From help:
Example:
