Modifying default note settings
ChristianSmith
My colleague is trying to modify the default information that pops up in the note when you create a hole using the hole tool. The note properties look like this
"&METRIC_SIZE &THREAD_SERIES - &THREAD_CLASS &STD_HOLE_TYPE &VAR_THREAD &THREAD_DEPTH
&NUMBER_SIZE DRILL ( &DIAMETER ) &VAR_DEPTH &DRILL_DEPTH -( &PATTERN_NO ) HOLE"
My colleague wants to know where the system pulls that information from so that he can edit the information that pops into the note by default.
4 REPLIES 4
Hello Chris,
To edit the note ,go to the model tree and select the note under the hole feature id. and Edit the properties.
Hope this will help you guys.
You can add or customise the note to display in the drawing.
Chander.
I'm actually looking for where this information is saved in the pro/e folder so that when a hole is created only the information I want to show up in the note, shows up. So it's beyond modifying anything in the pro/e interface.
Generally the hole folder will be in this location.
Try this
C:\ptc\proe\text\hole
(I guessed the Pro/E is installed in the C Drive).
Copy the required type of the hole ( NPT or the ISO and modifiy)
So for example if I don't want the lets say hole daimeter to appear in the note by default, I copy that file and delete the corresponding entries in the C:\ptc\proe\text\hole folder?
