My licience is lost when I am not online with company network
Do you have license at your local host or machine is getting license from server machine?
What error you are getting on starting Creo?
if you are using standard floating license, then you need permanent network connection to license server. If you disconnect from license server then license is lost after 1-3 minutes.
Discuss your "situation" with license administrator. For example you can borrow license from license server...
MH
