I was trying to add some new mapkeys to our custom tab in the ribbon in Creo 4-m090 and I discovered, much to my consternation that it's propagating those options to all modes of the ribbon. GRRRRRR!!!!
I've finally saw the help doc and David Martin's video on this subject. I suppose some would think this is an enhancement. I don't, it's an irritation, and it wasn't obvious how to change it without referring to additional documentation. A radio button in the UI to propagate or not propagate would have been helpful instead of hiding it under a right click.
My mapkeys are mode dependent. I don't want to add mapkeys to the ribbon in a mode where it will fail. Right clicking on each thing I add to limit it to a specific mode seems like a lot of extra work.
I'm hoping there is a hidden config that will restore the behavior to the old method where you have to be in the mode to add things to that mode. Is there such an option?
I didn't see one in the standard options.
Also editing my current ribbon appears to mess up the current uniqueness for each mode. I don't see a way to universally change the behavior anywhere in the UI.
I don't believe there is an option that does what you want... That said, there are tips for customization that you may find helpful.
Knowing how ribbon customizations behave does help but it doesn't make the process less tedious. Here are a few things that I think would make the process easier:
I hope this helps!
Ty
I am not aware of an option that will do what you are looking for. If it does exist you can find it by using Olaf Corten's utilities. He has a new website that will find all config options including hidden ones by date code release. Search your specific release and see if the names of any of the hidden options may apply. PTC does not support hidden config options and warns against using them as they are for development use only at PTC.
https://creosite.com/index.php/configuration/
I hope this helps!
Ty
Let me flesh out our environment for the community. Hopefully that will foster some better insights.
At the end of this I’ll make some suggestion for how this could be better. As it is, it’s a very poor implementation of how to propagate between modes.
As I’m sure you all know there are only three places the .ui file can be read from when Creo starts:
When editing the ribbon you want to ensure your only seeing one of these .ui files. I have custom startup script that remove all the other and place the one I’m editing in the start in dir:
I away confirm by checking support info. It should as below show only one .ui and it should have no path in front of it. With that confirmed I can edit the specific ribbon file.
I never modify the ribbons that come out of the box with Creo. If the user wants to do that they can. There is a startup script specifically for them to modify their own ribbon. (that doesn’t load the system ribbons).
Support.inf
Configuration Information
Configuration files read:
C:\ptc\Creo 4.0\M090\Common Files\text\config.sup
C:\ptc\Creo 4.0\M090\Common Files\text\config.pro
\\wci-home.llnl.gov\winhome\haigh1\config.pro
C:\ptc\Creo 4.0\M090\Common Files\text\menu_def.pro
creo_parametric_customization.ui
Modes
The appropriate ribbon tabs exist in the following modes:
I typically open a new file in each mode so I can do edits on all of them by switching between the files.
Tabs
We have two environments that each have unique start parts & drawing formats. The environment is built on the fly via the Creo startup scripts
The user will see two custom ribbons in each environment. The first ribbon on the left is named for the environment they are in, the last ribbon on the right is the Help ribbon.
Those two ribbons are loaded from two different location. The cache and the loadpoint.
Groups
The groups are named consistently between the modes so the UI become familiar to the users.
Cascades – I won’t list them, but they are similar in the different modes for consistency
Picks – Depending on how Creo operates the mapkeys may be unique to the mode or common to all modes
Examples of our Ribbon
Assembly Mode:
Drawing Mode:
Issues with the current behavior when editing the ribbon
For each Tab, and Group you have to be sure and uncheck Propagate Customization before you start editing the current ribbon file.
For the assembly mode, I have to do this 6 time. In Drawing mode 8 times.
At least this appears to be saved with the ribbon file once you do it.
How this should have been implemented
You should have been able to pick on cascades, and menu picks, and right clicked and selected Propagate too, and then be presented with the modes you want to propagate those specific picks to. If the Tab & Group doesn’t exist in that mode, then it should create those elements in that mode.
As for showing All Modes, that’s not very useful. There should have been a pick to just show what has been customized.
The system clearly knows which modes, tabs, groups, and cascades were customized.
I just received this answer from PTC.
There is a hidden config option “auto_customization_propagate Yes/No” where setting to “No” will not show the Propagate Customization option in Ribbon Customization dialog box and will be a pre-Creo 4.0 behavior.
That is good news! I didn't know that was available in Creo 4.0. I guess I should dig through the options more often!
Based on your heavily customized environment, I can see why you want the propagation functionality disabled. I think I'm going to leave it on for now.
Ty
