For the past few days I was looking for a right way to find a solution for this.. I know some basic java.since I already worked in c#,vba&VB.nt..
I searched this entire forum ,but still I'm not getting where to start jlink in eclipse or netbeans ..I can run a sample file..I understand the importance of protk.DAT and config.pro ,pfc.jar,jdk/jre version etc..so these are my questions:
1.should I need to create a package or .java or a .class file in eclipse/netbeans to start?
2.Even if create a java file with start& stop methods, I'm not able to debug in eclipse (mars) with jdk 1.8 for creo 2.0..after setting debug configuration in eclipse.. I got VM refused error..but I did registered my protk.DAT file with creo & java_jlink_command within java.exe-****8000***..still no luck..so how to dubug exactly in eclipse/netbeans?
3.My sample program is jar file. for that its working fine..but if I extract and change the path in protk.DAT also its not seems to be working.. So i don't know what is the mistake I have done ?
So I hope someone can help me to get the proper way to kick off this jlink.thank you...
FYI : I already worked in few cad customization projects using other programming languages..but I'm just a beginner in java.notes
Prakash -
Getting a new program to work does take some effort, especially when you're new to the environment. If this were one of my programs, I would have to assume that there are many mistakes to resolve before I get it to work the first time.
In my creo installation folder i didn't find any JRE folders to map java.exe .here is the folder structure "C:\tcwtxpocdata\PTC\Creo 2.0\Common Files\M150\x86e_win64\obj" after that there is no JRE\JDK folder..So shall i copy JDK folders manually to this location?
I don't recommend copying content like that into your Creo Parametric installation. You might try updating your installation by re-installing just the JLink component of Creo Parametric. I checked my own Creo Parametric 2.0 installation and noted that JRE was installed under Common Files\M100\x86e_win64\obj . You could also continue doing what you are trying now, which is to use a JRE installed outside of Creo.
Again, there are many reasons why your application isn't launching. Here are a few things you should check:
Good luck with this. It always takes time to get started in a new programming environment.
|+| M a r k |+|
Hi Prakash -
You should be able to use either Eclipse or NetBeans for your JLink projects. I used NetBeans about 10 years ago, but I have since switched to Eclipse. Most of the JLink programmers I talk to also use Eclipse.
Yes, you will need to create either. Since you want to use a debugger (and I consider that a good idea), I suggest that you use the .class files created by your IDE for debugging. When you're ready to send your JLink application to your users, that's the best time to create a .jar file.
It looks like you know something about specifying debugging options in your java.exe command. I know only one way to do that, and that is to specify the java.exe command in the environment variable PRO_JAVA_COMMAND. This is what I use:
C:\Program Files\Creo 3.0\M050\Common Files\x86e_win64\obj\JRE\bin\java.exe -Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8000
Make sure you use the same settings in your IDE.
When I run JLink programs that are not contained in a .jar file, I set the java_app_classpath field to be the \bin folder created by my Java compiler.
|+| M a r k |+|
Hi Mark,
Thanks for your guidance.But ,In my creo installation folder i didn't find any JRE folders to map java.exe .here is the folder structure "C:\tcwtxpocdata\PTC\Creo 2.0\Common Files\M150\x86e_win64\obj" after that there is no JRE\JDK folder..So shall i copy JDK folders manually to this location?
Also kindly guide me where i'm going wrong as per the following steps:
1.Created new Java Application->new package->New class file in eclipse
2.Above image is showing my Debug configuration Settings.
3.Written this program from another forum..
package com;
import java.io.IOException;
import com.ptc.cipjava.jxthrowable;
import com.ptc.pfc.pfcCommand.DefaultUICommandActionListener;
import com.ptc.pfc.pfcCommand.UICommand;
import com.ptc.pfc.pfcGlobal.pfcGlobal;
import com.ptc.pfc.pfcSession.Session;
public class LaunchCal {
public static String MSG_FILE = "messages.txt";
public static void start() throws jxthrowable {
Session currentSession = pfcGlobal.GetProESession();
String commandString = currentSession.GetMessageContents(
MSG_FILE, "-L.launcher.cmd", null);
String iconFile = currentSession.GetMessageContents(
MSG_FILE, "-L.launcher.ico", null);
UICommand cmd = currentSession.UICreateCommand("launcher",
new MenuButtonListener(commandString, currentSession));
cmd.SetIcon(iconFile);
cmd.Designate(MSG_FILE, "-L.launcher.label", null, null);
public static void stop() { /* EMPTY */ }
class MenuButtonListener extends DefaultUICommandActionListener {
private String commandString;
private Session currentSession;
public MenuButtonListener(String cmd, Session session) {
commandString = cmd;
currentSession = session;
public void OnCommand() throws jxthrowable {
try {
ProcessBuilder pb = new ProcessBuilder(commandString);
pb.start();
} catch (IOException e) {
currentSession.UIShowMessageDialog(
"Could not start " + commandString, null);
4.After that ,i changed the environment variables as you suggested ,name -PRO_JAVA_COMMAND value- C:\Program Files\Java\jre1.8.0_60\bin\java.exe-Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=8000.
5.Then i changed the protk.dat location & deleted jlink_java_command in configuration editor..after that clicked Auxiliary Applications in utilities to register the program..
then i clicked start button ,i got this error
This is my prot file
NAME LaunchCal
STARTUP JAVA
JAVA_APP_CLASS com.LaunchCal
JAVA_APP_START start
JAVA_APP_STOP stop
JAVA_APP_CLASSPATH C:\Users\xxx\workspace\Calculator
TEXT_DIR C:\Users\xxx\workspace\Calculator
ALLOW_STOP TRUE
DELAY_START TRUE
END
my class path C:\Users\xxxxx\workspace\Calculator\bin\com
This is my Folder structure
So kindly help me ..where exactly i'm making mistake...Thank you
Prakash -
|+| M a r k |+|
