New Creo Models are listed as "Released"
Mat
Hi there,
I have an odd "thing" in Creo and/or Windchill.
When I create a new Object (like a Assembly) and I edit its parameters, the lifecycle state is set to "Released":
only if I upload the file, the correct state is displayed:
@ptc: Is this behavior intended or is this a bug?
I am using Creo 10.0.5.0 with Windchill 12.0.2.19
Mat
(To:Mat)
OK, it seems, that this behavior only appears, if You create a subassembly within an assembly.
So my educated guess is, that Creo copies the state from the existing template at this step:
Right after its creation, the new sub assembly even shows the Version "D.2", which is the template's Version
But as soon as I save the new sub assembly, its version gets changed to ".0"
I consider this as a Bug in Creo, since not all attributes are set to a "default" value on creation and/or first save.
The "solution" is to wait the next decade until PTC fixes this problem.
Catalina
Moderator
(To:Mat)
Hi @Mat,
Thank you for your question!
Thanks for using the Community!
Best regards,
Catalina
PTC Community Moderator
PTC
MartinHanak
(To:Mat)
please ask PTC Support.
Martin Hanák
BenLoosli
(To:Mat)
Check your OIR for new EPMDocuments.
Mat
(To:Mat)
