Hi All,
I'm trying to change the order that the parameters are listed when a user creates a new part, from a template, in the new file options window. At the moment, the parameters are listed in alphabetical order, can I choose the order for these, without resorting to adding 1_, 2_ etc to the parameters?
This is on Creo 6.0.1.0.
Thanks in advance.
There is no option to define the order for parameters on part creation...
