Used to be that you could edit the definition of any component in an assembly, no matter what level of the assembly you had activated. In recent weeks we have noticed that sometimes we can only edit definition of parts in sub-assemblies while the main assembly is active,... and worse yet, sometimes not at all. Select a part, right click for Edit Definition, and nothing happens. No errors, no messages... nothing. Any thoughts? Did a setting in config.pro get messed up?
Chris Benner
Autodesk ® Expert Elite
