Can you flush a license in the new Flexnet manager through the interface? I had the need today. Myself and another admin could never figure it out.
Tried to use a command prompt. The ptcflush command returns "You are not a license administrator".
Did they remove this functionality?
It appears I have stumbled upon my own answer. This paragraph is located in the
Creo3 Install guide. Document - CS47365 also suggests this solution. It just didn't appear in my search because the knowledge base search tool uses a worthless algorythm.
