Hello Team
The license server is down and how can i restart. approx 7 person effected in my organization.
Please help
Hi Martin
I am from technical team not the user. Let me cross check with user and dc team and back to you. Thank you
@DG_10560620 wrote:
Hello Team
Please help
login at license server and run ptcstatus.bat. Publish the output of this command.
What operating system is installed on license server?
Hi Martin,
Thank you for response. I have crossed check with DC cloud team and they informed there is no issue with license server.
@DG_10560620 wrote:
Hi Martin,
unfortunately I do not understand the contents of creo1.png. I need to see output of ptcstatus.bat command launched on server.
Also ... can you ping server successfully ?
Hi Martin
