No annotation module available
ptc-2291125
Dear members of forum, I've lost my annotation-module under menue "application" (Anwendungen) since a few months. See attachement. I tried to solve this problem by deinstalling the programm. After new installation of "CoCreate Modeling PE" it was the same as before. The 3D-modeling is OK Does anyone know this problem and may help me? Thanks a lot Sebastian
Dear Sir, can you please test the following. 1. Stop Modeling PE. 2. Create a security copy of the following directory. D:\User Profiles\<name>\Application Data\CoCreate\Modeling PE\20.00 (E.g> Copy this into temp) 3. Then delete the complete directory named above 4. Restart Modeling PE. Post the result here. It might have happened that the UI definition files have been changed. If it remains an issue - can you load a bd2 file into your session and let us know what happens then.
