If I run ptcsetup for ProE wildfire 4, it shows the "Interface for JT" as already installed, but I can't find .jt when I try to open or save a file. Is there something else I have to enable in order to work with .jt files? Should I try to reinstall?
Alternatively, how do I know if I actually have the jt interface installed properly?
Yeoung
license module INTF_FOR_JT is required to save as a .jt file. Does your license contain this module ?
Martin Hanak
