Create a rep that hides internals and then step it out and import it back in with the hidden config below turned on.
intf3d_in_as_part YES
Note that this config option is hidden because it is not fully supported. It doesn't support mixed units and it can cause Creo to crash. With it enabled though you can import a step assembly as a single merged part.
