Not able to import Part from Creo workspace to windchill
SG_10754829
2-Explorer
I am using Creo Parametric Release 4.0 and DatecodeM130
Here are the errors that I faced
CAD Part - 418-06-p2620.prt is not unique.
This message means that the file name you are importing already exists in Windchill. Here are a few things to try:
First:
  • Synchronize and refresh the workspace. Make sure everything is up to date.
  • Upload - if this fails so will your check in. I use this as a test.
Here are your options.
  • Search Windchill for that file name. If you get a match and the geometry is the same, you can just replace the version in your workspace with the one from commonspace.
  • Rename the part in your workspace to something else unique. This will allow you to check in the file.
  • Rename the existing part in commonspace and keep the file name the same in the workspace. You need to know what you're doing with this option.
