Notebook/Layout: In previous versions (prior to Creo 3.0), users we're able to just double click in the table cell to edit the value of a parameter. Now when double clicking, the system tries to edit the parameter name instead of the value. Is this just a config setting or the new way of doing things? If the later can it be reset to the old way.
Change your smart filter (bottom right corner of the screen) to "Individual Text".
That answered my question. Thank you Tom.
Hi Richard,
If you don't mind, please mark Tom's response as the Correct Answer, so that anyone else who may have the same issue, will find the solution quickly.
Amit
Thanks for doing that Richard.
