Olaf's Benchmarks
Marshdamp
7-Bedrock
Olaf's Benchmarks
I'm trying to run the WF4 benchmark on a Lenovo W510 freshly loaded with
Windows XP pro 32bit. I loaded WF4 M110 for the testing. It gets to test
#18 where it saves 2 jpeg images of the current model and pro/e exits
with a memory error right when the trail file hits the OK button to do
the first save. I've tried different combinations of video and mouse
drivers and it still always exits at this test. The really strange part
is that if we build the W510 by using an image of our W500 setup (also
windows xp pro 32bit) and switch the ATI driver out for the Nvidia
driver the benchmark will complete successfully. Does anyone have any
ideas on what might be causing the problem?
A couple people suggested that I should check for the 3GB switch and
they were right! The image for our W500 had the switch and when the
W510 was built from scratch I forgot to turn the switch on. Thanks for
the help!
/Michael
